L
lozz
Guest
The JTD seems to be idling a bit high at the moment , she's sitting at about 1200rpm at idle where usually she used to sit at about 800-900rpm, also when i put the brake on it holds the revs high, but when i release the brake the revs return to normal, anyon know whats going on, also the temp meter is sitting a little higher than normal its only one notch above center but it never usually goes higher than the middle notch any help would be great
Lozz
Lozz
