A
Anonymous
Guest
hi guys, every now and then my bravo judders back and forth this happens at low revs about 1500rpm but only in second gear, this doesn't always happen either only once in a while, the only thing that i could think of is that im unsure when the plugs were last changed so may be they're knakard if this is the case could this be causing the juddering? thanks
gaz
gaz
