J jonoc Guest Oct 17, 2005 #1 I should have probably bought thr 100bhp model or the 105 jtd. I did'nt so is there an easy cheap way to get more power from my TD75
I Ian (Geforce) Guest Oct 17, 2005 #2 Don't think there is unfortunately. Maybe removing the CAT will give you another 5bhp, but don't expect anything astronomical. The TD75/TD100 cannot be remapped either. Sorry.
L lozz Guest Oct 17, 2005 #3 yes it can, try nige at www.angeltuning.co.uk he might do the older mechanical diesels if not the www.dervdoctor.co.uk tune the mechanical diesels Lozz
L lozz Guest Oct 17, 2005 #4 also forgot to say, you can get manifolds and decats made and get your turbo reworked aswell the guys at www.turbotechnics.co.uk can do this, just depends how much you want to spend on it Lozz
I Ian Guest Oct 17, 2005 #7 Surely that's called altering the fuel pump and not a "remap" Mr. Pedantic here.. I knew that TD's could be tuned by altering something mechanically, just knew it wasn't something to do with the ECU.
I Ian Guest Oct 17, 2005 #9 I did mate, read up. I said "The TD75/TD100 cannot be remapped either. Sorry"
