A
Anonymous
Guest
Hi all,
Thanks to all for help in past with my cambelt saga.
Now replaced head using Sealey cam locking tools with No.1 piston at TDC as instructed & fitted cambelt. BUT how do I know if its on ignition stroke or not when I set TDC on No. 1 with the head off? Where does the timing come from the crankshaft or cams as I could have TDC on No. 1 but NOT on ignition stroke if timing comes from crankshaft. If timing comes from Camshaft then surely it doesnt matter as long as No.1 is TDC when fitting cam belt.
To check it, now with the head and cambelt on, how do I tell when No. 1 is TDC on IGNITION stroke.
ALSO to be sure when sitting in the drivers seat is No. 1 cylinder on the right or left of the engine ie on timing belt end or flywheel end?
Many thanks
Many thanks
