I never said that I was connecting the boost valve to the throttle housing, or the boost valve gave it more power? What was the point to your reply it gave no info on the subjet i raised
Then why ask where it is if you ain't gonna fit the fuel waste valve to it? DUH!
The throttle housing is the thing with the throttle cable attached to it and usually somewhere in the pipe between the air filter and the engine. Its not hard to miss.
