THROTTLE HOUSING ON A BRAVO 1.6
G
GAZ
Guest
I NEED TO FIND THE THROTTLE HOUSING SO I CAN FIT A POWER BOOST VALVE ON MY BRAVO 1.6SX. ANY 1 NO WHERE ITS LOCATED ON THE ENGINE?
1) a power boost valve does not fit to the throttle housing
2) they give no more power, just less MPG
3) caps lock off please :)
I never said that I was connecting the boost valve to the throttle housing, or the boost valve gave it more power? What was the point to your reply it gave no info on the subjet i raised :)
Then why ask where it is if you ain't gonna fit the fuel waste valve to it? ;) DUH! :)
The throttle housing is the thing with the throttle cable attached to it and usually somewhere in the pipe between the air filter and the engine. Its not hard to miss. :)
Cheers you sarcastic B*****D! :)
The reason why I asked is because the detailed instructions (im being sarcastic) asked for the throttle housing to be removed.
That I am :)
GOK why you need to remove it, its nowhere near the fuel pressure reg. Thats hidden between tghe manifold and the cam cover.
