J
John
Guest
Hello all, I'm suffering from something I found a few times looking on here - a very low pressure dribble coming out of the front windscreen jets. I wiggled with a pin as suggested but that didn't fix it. I just took it to a frindly garage who disconnected the hose and put some pressure through it, but that's all fine - so it looks like the pump is clogged or broken. As with many things in the HGT bay it's all really congested - has anyone removed/replaced the washer pump and if so is it something you'd recommend to a novice? Thanks very much.
