B
Babar Malik
Guest
Rear Wiper has died, no fuses seem to be blown. Rear high level brake light and rear washer work ok so i'm assuming its not the connection blocks on the back sill and tailgate? If its the motor could i check by just using a multimeter between the motor terminals to look for 12v when the switch is on? If it is the motor where's the best place to get a cheap new replacement?
