P Pete T Guest Mar 31, 2004 #1 can anybody tell me what colour the positive and negative speaker wires are in the back of the bravo sx100? i cant work out which is which cheers Pete T
M marko Guest Mar 31, 2004 #2 look at where the cable is fixed to the speaker - the terminal for the positive should be bigger than the negative.
A Alan Guest Mar 31, 2004 #3 Re: Re: Speaker wiring the wire connectors at theback of the bravo are the same size, have looked in the haynes but it does not say which are + & -, it just says: Rear left light blue/red white/red rear right light blue/yellow light blue/white anyone else?
A Anonymous Guest Mar 31, 2004 #5 Re: Re: Re: Re: Speaker wiring i had this problem, in the end i guessed then used a special test CD to get them correct. You listen to this CD and it allows you to work out if they are connected in phase and the right way out. My dad had it lying around. Jonathan
OP OP P Pete T Guest Apr 1, 2004 #6 Re: Re: Re: Re: Re: Speaker wiring wot were ur findings then?? or wasnt that for the standard wiring?
