G
Gary F
Guest
Right.
When the engine is warm to hot when you release the clutch in first, just as it engages the car judders and the revs drop and it takes quite a bit more acceleration than usual to get it going, does not do it with any other gear and usually only does it when the engine is warm and on slight inclines or hills.
One day the shaking got so violent I had to just pull away in 2nd gear all the time.
My clutch has already been replaced about 8 months ago and has a years warranty with it so if it is the clutch itself I should get it done free.
Is it the clutch?
If not, how much to fix it?
And today I noticed a noise similar to the engine idle noise but it goes away if you press the clutch. It's not a whiney noise like it was when the thrust bearing broke the last time.
Gaz
Fiat Bravo 1.4sx 75,000 miles P reg 1996
Is it the clutch?
Gaz
