Old 27-02-2004   #1
Woody
Guest
Rear tailgate smoothing
How much should I expect to pay to have the rear tailgate smoothed and sprayed?
Old 27-02-2004   #2
Danny
Guest
Re: Rear tailgate smoothing
i wouldnt mind knowing either so bump.
Old 27-02-2004   #3
Anonymous
Guest
Re: Re: Rear tailgate smoothing
WTF DOES BUMP MEAN.....
Smee
Old 27-02-2004   #4
Anonymous
Guest
Re: Re: Re: Rear tailgate smoothing
as in to bump it to the top to get it noticed more.
Old 27-02-2004   #5
Bahney
Guest
Re: Re: Re: Re: Rear tailgate smoothing
most places will charge around 250, i just got mine done from a local bodyshop for 100 though which is a bargain
Old 27-02-2004   #6
mousey
Guest
Re: Re: Re: Re: Re: Rear tailgate smoothing
gettin mine done at local body shop for 120! well chuft, but am getin alot done so that is why it is cheaper!
Old 27-02-2004   #7
mousey
Guest
Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
woody - just noticed u r from fife! this place is in forfar, could be worth a shout!
Old 27-02-2004   #8
Markpro
Guest
Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
Hey Woody where about in Fife are you, I'm In Kirkcaldy
Old 28-02-2004   #9
jamesp
Guest
Re: Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
Dont pay anyone to do it apart from paint it.
Ive done 4, its soo easy and takes 4hrs tops.
First remove the gay handle.
Get some small bodywork patching mesh and aproxy it to cover the holes. Mix up a tin of filler and paste it in till your arm drops off.
Next sand down, fill, sand, fill again. Then a bit of spray primer and ready for painting.
j
Old 28-02-2004   #10
danny
Guest
Re: Re: Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
are you willing to do mine if i paid you .
Old 28-02-2004   #11
gordon b
Guest
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
my mate works in a bodyshop and he says that if u just fill it with filler it will crack due to the expantion and reduction of the filer and the vibrations
Old 01-03-2004   #12
Woody
Guest
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
I stay in Livingston but work in the St Andrews area.
Have you got a number for the bloke in forfar?
Old 02-03-2004   #13
miss_bravo
Guest
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
I'm in Falkirk and I know that there a place here that does it for about 200 maybe less, if your interested then e-mail me and I'll get you some more info.
Old 02-03-2004   #14
Dan
Guest
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
if jamesp has done 4 of them like that then i reckon that's a sweet way to do it - you've got nothing to lose either if you were going to get it done at a bodyshop anyway!
Dan
Old 02-03-2004   #15
Paul R
Guest
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Rear tailgate smoothing
I work at a vodyshop and i will never ever suggest using purly filler!
If you want it done then get a plate welded in!
No affence intended james but filler wont work!My be if you have a standard sound system and you dont slam the boot EVER! but if you put a sub in the boot the pressure caused by the sub will crack the filler, and if you slam the boot the filler will probably crack!
Agreed dan, you have nothing to lose but the chances are you will need it redoing so why bother!!
Paul R
