J
joem
Guest
I have a Marea 2L 20V, and have replaced the Slave Cylinder for the Clutch - the supposed cause of the Floppy Clutch Pedal Syndrome. But now, how to get it to work? Is it simply a case of bleeding the brakes, or is there some methodology to bleeding the clutch as well? How to do it? I mean, there's no pedal to depress (or there is, but it has no tension). Will pumping the lever into which the cylinder is seated do the trick?
Help,
Thanks,
JoeM
Help,
Thanks,
JoeM
