Oh oh,i see oil on timing belt cover?
A
Adrian
Guest
i can see fresh oil behind the timing belt cover and at the bottom of the cover? what does it sound like has gone here?
thats what mine is like now...i think its the camshaft cover oil seal....is there oil going round the gap between the camshaft cover and the gasketty stuff below it?
not sure
can't really see properely cause of the muck and stuff,i wonder if this is the cause of my pinking problem? and not the air meter like the garage says?
OIL IN TIMING COVER
IF oil is in or on the cambelt cover/cambelt it's not the pinking to worry it the belt IT MAY GIVE UP AND SNAP by oil contamination.
now i'm confused?
the oil leak is the rocker cover gasket has gone being done next week,but i've just tried a new air flow meter like the garage said and my pinking problem still exists! wtf is going on? i don't know what to do? all he noticed on the computer was the injector pulses were reading 11ms and he said should be 14ms absoloute min,so what is causing the injector pulses to be low? and would that cause pinking?
Similar threads
D
Replies
1
Views
470
Dark Lurker
D
D
Replies
Views
334
Dark Lurker
D
F
Replies
Views
7K
F1-ANG
F
K
Replies
7
Views
6K
keval
K
K
Replies
Views
6K
Keval
K
