P
Peter Longman
Guest
Dear All, Can anybody help? Air conditioning is not working properly. The switch on the dash lights up as it should but there is no voltage at the electric clutch on the compressor. There is good conductivity at the sensor on the compressor also, so there is probably enough refridgerant in there too. When the switch on the dash is pressed the fan behind the glove box starts normally (it goes to first speed). But still no voltage to the electronic compressor clutch. I have even wired the compressor clutch manually from the battery and it kicks in like a dream.
Any ideas, are there any fuses, relays or connections that I should be checking?, Pete
