Right hand side brake light not working
E
evo~paul
Guest
Does anyone know how to get into the rear light clusters, my right hand side rear brake light isn't working.
Cheers in advance
Easy Peasy Mate
Inside the boot(on left and right hand sides) you will see a dark grey plastic cover, kind of oblong in shape. At the top is a locking catch, turn the screw 1/2 a turn, don't even need a screw driver, a key will do. This will enable the cover to be removed.
Then you are at the rear of the light cluster, two plastic bolts which you can remove by hand. Then you can pull the cluster out getting access to the bulbs.
It's a 2 minute job, no tools needed.
(P.S. The brake light is the top one)
Steve.
Cheers Mate
Cheers Steve, too dark last night, so had a look this morning, and could see how easy it was, feel like a right plum now !
anyway thanks for responding
Similar threads
M
Replies
Views
6K
mick gibbons
M
D
Replies
5
Views
458
Wayne
W
T
Replies
13
Views
751
A
