Gearbox & Engine Oil Change
N
Neil
Guest
Im about to change the engine and gear box oil, anyone any suggestions as to a top notch replacement for use in my Bravo HGT ?
Oils...
Hi Neil;
As U didn't mention your HGTs Km. I can not say much but, I can advice some in general as a proud owner of a HGT.
Engine; The use of fully synthetic oils improve the protection & engine performance. U can use lots of oils in the recommended range which is 10W-40. Don't use the thinner oils like xW-30, cause they're very thin that can penetrate the combustion chamber unfortunately. Keep the viscosity which is recommended.
I prefer Shell Helix Ultra 5W-40 Fully synthetic !
( In general the first number before the "W" means Winter performance; which must be low, and the last number with two digits means the viscosity. The lower numbers means the thinner oil film between surfaces.)
Transmission; I tried lots of additives & oils brands with lots of failure. Finally I got the best transmission oil by experiencing;
Castrol SAF-XO 75W-90 !!! U can't believe the result.
Hope those stuff helps.
See ya !
gearbox oil....
I know you need to change it somewhere down the line - but how many miles b4 doing so? mine is 36k at the mo. what about yours?
Gear Box Oil Change
Im at 44k but as I have just purchased the car I was thinking it would be wise to change it.
Change Them All..
Definitely change the oils with proper & improved ones.
P.S: Don't forget to use a quality oil filter.
P.S 2: U can also change the radiator liquid, 2/3 Anti-Frezee + 1/3 Diluted water will be fine !
Also change the brake fluid with a DOT 4 one.
Where do I get Castrol SAF-XO-75VV-90
Cannot find it localy, Fife.
Please help.
Castrol
Check the Castrol web site for a dealer near u or contact to the nearest authorised BMW( Sorry..) service.
As I know their offical & recommended oil is Castrol..
Hope this helps.
See ya !
Similar threads
L
Replies
1
Views
586
Dark Lurker
D
M
Replies
6
Views
294
M
I
Replies
2
Views
747
Dark Lurker
D
D
Replies
Views
632
David
D
