S
softlad
Guest
I have a Marea TD125 HLX.
This is essentially identical to a brava but bigger.
one of the integral front fog lamps has smashed and i have got a second hand replacement. I have undone the only retaining screw I can see in the cowling but it will not move so I presume it must be fixed elsewhere.
Any ideas?
also the courtesy light dosnt come on when drivers door opened. I believe the switch is inside the door closer mechanism. Is this true and if so how can i inspect/ repair it.
I have been to 3 motorist shops and cant get a haynes manual for my model so any help would be apreciated.
Andrew
Any ideas?
Andrew
