Ecodrive - what does it monitor?
bartram108
North East
So far I've resisted temptation to install this function as I know I'm an inefficient driver and I don't need a computer to tell me.
But a question - what does the software actually monitor? Is it just the habits of the driver or does it also check that the engine is performing correctly; eg will it report if the engine is misfiring and not running smoothly?
Ecodrive is not a diagnostic tool . It monitors driving efficiency and gives you a score out of 100. It then makes suggestions on how you can improve your driving style to maximise fuel & C02 savings.
It is also very difficult to get scores above about 70-ish in normal traffic without driving like a Saint. I does record mileage, fuel economy and tells you how much your fuel cost on a journey is which is useful.
which bravo's have this system installed? Only the diesel eco version?
Fiats with Blue&Me use Eco:Drive. It's just a software you install and helps you drive the 'ecological way'. I am happy not to have it. Petrol consumption is enough for me.:devil:
I do want to try the ecodrive program, i've downloaded it from the Fiat website.
The tutorial is on the website, in a few steps.
One step (i believe it's the third step) tells you to put the USB stick in the computer so the program wil prepare it four installing the ecodrive-program
on the stick.
I've read all the instructions but I hope someone can clear this;
Do I have to use a emty usb stick to use the ecodrive program or can it be installed/placed on a stick where there is already music/nav-soft on?
