Comment
Guide Tools
<!-- google_ad_section_start -->1.3 Multijet Turbo Check and Repair<!-- google_ad_section_end -->
Published by IanDavis
25-03-2016
Difficulty Level: 4
User Rated:Unrated
Refitting
Refit the turbo to the engine. Before connecting the oil inlet prime it generously with oil. When first starting ignore the glowplug light, crank immediately. This will prolong the cranking time, allowing oil to fill the feed pipe before the engine starts. When it starts, do not rev. Allow to idle for 30 secs to establish the oil flow before increasing the turbo speed too much.
Likes Scottmurphy, varesecrazy liked this post
Contents
<<  <    (Page 3 of 3)    > >>
Old 21-11-2017   #1
Re: 1.3 Multijet Turbo Check and Repair
I'm having a problem similar to this as soon as my fiat doblo 1.3 gets warm it starts to shut down at 3.5 thou rpm And smokes too. I changed the pressure booster sensor and it's stopped Smoking but still shutting down any ideas what this could be the turbo has been checked too
Scottmurphy is offline Reply With Quote Quote
Old 21-11-2017   #2
You active my friend?
Old 23-08-2018   #3
Hi, where can I find the boost pressure sensor? I suspect mine is faulty, I’m getting the turbo overspeed warning but it only happens intermittently which suggests something else.
SatSteve is offline Reply With Quote Quote
Comment
Guide Tools
(T) Bravo 1.9diesele Multijet - Check engine light JohnTzn Bravo 4 26-03-2016 22:16
(T) Bravo 1.6 Multijet '08 plate check engine issue iainfarrell Bravo 9 21-12-2014 20:50
(T) Doblo 1.3 Multijet Limp Mode No Check Light d3d Doblo 0 09-07-2013 14:14
2009 bravo 1.6 multijet automatic says check transmission jacobjohn7 Tech Talk 2 21-03-2012 18:38
(T) Punto Van 1.3 TD Multijet - Check engine light contego Punto (Mk2/2b) 15 21-07-2011 07:40
