Comment
Guide Tools
<!-- google_ad_section_start -->1.3 Multijet Turbo Check and Repair<!-- google_ad_section_end -->
Published by IanDavis
25-03-2016
Difficulty Level: 4
User Rated:Unrated
Repair
Undo the two screws holding the actuator bracket to the compressor housing. As they are loosened the rod will be drawn into the can by the spring inside. Do not undo the locknut on the rod, if you turn the adjuster you will lose the calibration. When the can is free carefully rotate it on the rod until it can be moved sideways. This is not good for the diaphragm, so keep the rotation to the mimimum. The compressor housing is now vulnerable so put one of the screws back in to make sure it does not get dislodged in the following process.
If the wastegate is stuck in the turbine housing (unlikely), separate the catalyst from the turbo and investigate.
If the rod end is tight on the crank pin (more likely), work the rod around the pin back and forth as far as possible. This will loosen and expel the corrosion that has caused it to stick. When it is completely free, remove the temporarily installed screw, place the actuator back in its correct position and rotate it back to align the bracket with the compressor housing. Refit the two screws. As they are tightened the actuator moves back into position, tensioning the spring as it goes.
Use the footpump to check that it moves freely. Reconnect the hose to the pipe on the compressor housing.
Likes Scottmurphy, varesecrazy liked this post
Contents
<<  <    Next Page: Refitting (Page 2 of 3)    >  >>
Old 21-11-2017   #1
Re: 1.3 Multijet Turbo Check and Repair
I'm having a problem similar to this as soon as my fiat doblo 1.3 gets warm it starts to shut down at 3.5 thou rpm And smokes too. I changed the pressure booster sensor and it's stopped Smoking but still shutting down any ideas what this could be the turbo has been checked too
Scottmurphy is offline Reply With Quote Quote
Old 21-11-2017   #2
You active my friend?
Old 23-08-2018   #3
Hi, where can I find the boost pressure sensor? I suspect mine is faulty, I’m getting the turbo overspeed warning but it only happens intermittently which suggests something else.
SatSteve is offline Reply With Quote Quote
Comment
Guide Tools
(T) Bravo 1.9diesele Multijet - Check engine light JohnTzn Bravo 4 26-03-2016 22:16
(T) Bravo 1.6 Multijet '08 plate check engine issue iainfarrell Bravo 9 21-12-2014 20:50
(T) Doblo 1.3 Multijet Limp Mode No Check Light d3d Doblo 0 09-07-2013 14:14
2009 bravo 1.6 multijet automatic says check transmission jacobjohn7 Tech Talk 2 21-03-2012 18:38
(T) Punto Van 1.3 TD Multijet - Check engine light contego Punto (Mk2/2b) 15 21-07-2011 07:40
