![]() | #1 | ||
Posts: 8 Thanks: 0 Trader Rating: 0 ![]() | Injector 1.9jtd 110kw Hello, what is the interchangeability of the injector marked 0445110391 and 0445110243?
![]() | #2 | ||
Posts: 4,324 Thanks: 438 Trader Rating: 0 ![]() | Re: Injector 1.9jtd 110kw Those do not look like injector part numbers. Typical part number for your engine is 55200259 or 55198217. The numbers you quote may be serial numbers. Also note if you change the injector, even swapping position on the engine you have to tell the ECU the calibration code for the injector in each position. MultiECUscan will do this. Its normally a 9 digit code. Robert G8RPI
![]() | #3 | ||
Posts: 8 Thanks: 0 Trader Rating: 0 ![]() | Re: Injector 1.9jtd 110kw Thank you for the answer but these numbers are on the injector I have the end number 391 and my friend 243 and they will both be ordered but I don't know if I can replace the injector with the end number 391 with the injector 243?
![]() | #4 | ||
Posts: 4,493 Thanks: 324 Trader Rating: 0 ![]() | Re: Injector 1.9jtd 110kw I think these are BOSCH OEM part numbers. Google the numbers yourself. Fiat like all manufacturers purchase from BOSCH/Others as OEM suppliers. So they purchase say BOSCH 12345678 and renumber as Fiat part 987654321. There are of course variations on the same schema that add a little variance to confuse us but these can be unravelled with a little research effort.
![]() | flisko | Bravo | 1 | 24-02-2020 22:48 |
![]() | flisko | Croma | 3 | 03-10-2017 22:35 |
![]() | flisko | Croma | 7 | 01-08-2017 09:36 |
![]() | flisko | Bravo | 10 | 07-12-2016 19:21 |
![]() | flisko | Croma | 7 | 16-11-2016 23:40 |
