Hi All,
1.9JTD 8v.
Anyone any ideas why Front left rpm sensor ( new hub , bearing and sensor) - not installed in knuckle when plugged in clears the ABS warning light, but when installed in the knuckle the warning light comes back on. :bang:
Both new and old sensor , when multimeter is used , to check sensor,shows an open circuit. This is the 3rd hub fitted in so many years, all being replaced due to ABS stating no signal from left front wheel sensor.
The wiring from sensor plug to ABS ECU pins 19 & 20 seems to show full continuity.
Thanks for any assistance in advance.
1.9JTD 8v.
