im Axle Specialists
Old 01-12-2019   #1
Weird wire in fuse box
Having a look at the internal fuse box there seems to be a wire that has been added by a previous owner.
Two red wires with in-line fuse connectors.
I'm not expecting anyone to identify what it's for (unless you think you can) but I was wondering if anyone can say what kind of point it is plugged into? The diagram in the manual only details the fuses and not the other points in the box.
The car does have a tow bar and associated electrics so I suppose it could be related to this, but I've not had a chance to track the wire yet.
JimNu is offline Reply With Quote Quote
Old 01-12-2019   #2
s130 has donated!
Re: Weird wire in fuse box
I would be over 50% in favour of tow bar electric feeds.
Clues are:
1) Red large (2.5mm squared) cross sectional area wires
2) Presence of two (both possibly fused a 15A each)
One wire will be to supply 12V for the bypass relay that controls and powers the trainer/caravan running lights and to supply 12V to the caravan to charge the on-board battery.
The other will be to supply 12V power to the caravan to run the on-board fridge.
Thanks JimNu thanked for this post
s130 is offline Reply With Quote Quote
Old 02-12-2019   #3
Quote Originally Posted by s130 View Post
Clues are:
Cheers. I had completely forgotten about the tow bar until I got the end of the post, it does make the most sense.
(T) Main fuse box - fuse allocations G1KEA 500X 15 28-04-2018 21:14
(T) F30 15amp fuse melted in fuse box above battery. dtimmins1985 Stilo 4 13-12-2017 13:44
Punto Evo Help! Unknown fuse box type: fuse diagram needed Punto2009TF Newbie Central 2 25-03-2017 18:11
(T) Weird fuse box?? maxi26 Uno 3 13-09-2011 07:09
(T) Spare Fuse Position in Fuse Box? JonActiveSport Grande Punto 4 31-12-2009 08:40
