Thread Tools
Old 30-07-2019   #1
water leak
hi just bought my croma a couple of days ago have noticed water leaking into passenger footwell even when the air con is switched off weather has been red hot over here in north wales the past few days any suggestions would be much appreciated thanks in advance
tezza46 is offline Reply With Quote Quote
Old 30-07-2019   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: water leak
Can you tell if it's water or coolant? Checck the level in the coolant tank and make sure it isn't going down.
Possibilites are a coolant leak in the heater circuit (not good news), air cononditioning condensate, leakage from a blocked scuttle / poorly installed pollen filter. or leaking sunroof / door seals.
It's not a problem I've seen on my Croma.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 30-07-2019   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: water leak
Thread Tools
(T) Water leak Andycabs Scudo 12 05-09-2012 06:31
(T) Seicento Oil leak & seperate Water Leak from Head?!?! Please help. Hamilton Cinquecento / Seicento 22 21-10-2010 13:45
(T) Water leak Jules Sei Cinquecento / Seicento 7 29-05-2009 18:40
(T) water leak and air bubbling in water tank desypete Punto (Mk2/2b) 11 17-05-2009 17:09
(G) Where does the water leak from if heater matrix has a leak? BrotherBud Bravo / Brava 4 10-07-2007 18:21
