![]() | #1 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Oil problem Hay guys! I'm new on fiat club. From yesterday I have a problem with my fiat croma 1.9 jtd 150hp automatic. After a highway drive about 50 km range this lamp lit meAttachment 198574. I quit the car and wait for half an hour. then I set it on, and the lamp went out. The oil level is good I checked yesterday and this morning. What could be the problem.
![]() | #2 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil problem
![]() | #3 | ||
Posts: 4,408 Thanks: 322 Trader Rating: 0 ![]() | Re: Oil problem Are you checking the correct oil. The warning symbol is I believe for the automatic gearbox oil and not the engine oil.
![]() | #4 | ||
Posts: 4,267 Thanks: 430 Trader Rating: 0 ![]() | Re: Oil problem Double check the oil level and if it is OK have a look at the sensor connections. Could just be a random electrical glitch. I had it come on once in four years for no reason. Welcome to Croma ownership. obert G8RPI.
![]() | #5 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil problem I check the oil twice today and it is OK. I must check the sensor tomorrow. Thanks for help.
![]() | #6 | ||
![]() | #7 | ||
![]() | #8 | ||
![]() | #9 | ||
![]() | #10 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil problem I have one more question. Does the car have a oil check valve for gears? And where can I find it? Thanks for your help.
![]() | #11 | ||
Posts: 121 Thanks: 2 Trader Rating: 0 ![]() | Re: Oil problem Sometimes if the car is at a steep angle it could flick it on happened to me once, I got worried but never seen it since that day
![]() | #12 | ||
Posts: 4,267 Thanks: 430 Trader Rating: 0 ![]() | Re: Oil problem Autobox level chk.pdf This is from the electronic service manual "eLearn" which you can find in the downloads section of the forum. Not sure why the pdf says 2.2 engine, I'd selected the 1.9 16V. Autobox is the same for both. Robert G8RPI
![]() | #13 | ||
![]() | #14 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil problem Thanks guys for everything!
Emissions problem part two/ is it stem oil seals causing the problem | MozaRS | Tech Talk | 13 | 10-07-2011 03:12 |
![]() | Chri5 | 500 | 2 | 07-03-2011 22:43 |
![]() | newfiatowner1 | Cinquecento / Seicento | 39 | 10-04-2009 14:17 |
![]() | steveshipp | Ducato | 0 | 11-08-2007 08:39 |
Oil Problem.. | softwarez | Leisure Lounge | 4 | 16-01-2006 01:10 |
