Following my fuel regulator connection failure I have had two other faults appear. One is co-incidental, No.3 glow plug, so that’s on order. More worryingly, the fuel gauge is reading empty with the low fuel light flashing. The fuel sender in tank is a simple resistive type that is connected to the Body Computer (BC, part of fuse box by the drivers knee). The BC shows 0% fuel on Multiecuscan, but if I unplug the tank unit it gives a fault of open circuit sender. Checking the resistance at the BC (plug D, below EOBD socket, pins 4 and 15) show correct value, 155 Ohms, about ½ full. The range is 300 ohms for 1 litre to 50 ohms for 62l. This all points to a failed fuel level input on the BC. Research on the forum comes up with a similar failure when plug D was pulled. It seems the BC does not like having the fuel sender unplugged with power on. The problem is that the BC is reputedly part of the CODE system, but I can’t find any firm information on what is required when changing it. So I have a number of options:
1/ Pay £x00s for a new one from Fiat – not going to happen.
2/ Change the BC, TEG, Steering lock and ECU for used set – probably not going to happen.
3/ Fix the existing BC fuel sensor input.
4/ Fit used BC and see what happens
5/ if 4/ does not work, identify the “chip” that contains the CODE data and swap to the “new” BC.
6/ Disconnect the sensor from the BC and connect it to a new DIY fuel gauge.
So to start with 3/, 4/or 5/ I’ve ordered a cheap used BC from EBAY. It will be here Wednesday and I’ll open it up and see what’s what inside. It’s pretty poor design to have the fuel gauge fail because the sensor was disconnected/connected with power on. The BC appears to be over-reading the resistance but still working to some extent because it can detect the open circuit state. It looks like it may be driving too much current into the sensor.
Watch this space.
Robert G8RPI
Watch this space.
Robert G8RPI
