Thread Tools
Old 18-09-2018   #1
Broken down various fault codes
Hi All,
Another problem with the Croma, this time it was running ok and then just stopped completely.
Error codes per mes are as follows:
P0340 phase sensor camshaft position sensor circuit malfunction. Fault is now not detected but stored in memory. Engine temp was 86.7 Deg c fuel pressure 588 bar boost pressure 1788mbar engine speed 1196 rpm.
P2293 fuel pressure. Fault is present now engine temp 86.7 Deg c fuel pressure 91 bar boost pressure 1116 mbar engine speed 1288 rpm
P0087 pressure on injector support fault not present now but stored in memory. Engine temp 86.7 Deg c rpm 1058 fuel pressure 70 bar boost pressure 1068 mbar
P2294 Fuel pressure. Fault is present now. Engine temp 72.7 Deg c. Engine speed 276 rpm fuel pressure 7 bar boost pressure 984 mbar.
When trying to turn it over it makes a rapid high pitched sound when trying to turn over.
I suspect it might be related to the starting problem I've been having recently.
Any ideas or suggestions would be gratefully received.
BrianMcL is offline Reply With Quote Quote
Old 18-09-2018   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Broken down various fault codes
Quote Originally Posted by BrianMcL View Post
Hi All,
Sounds like it might be the high pressure fuel pump. What is the desired fuel pressure, actual fuel pressure and regultor opening when you are cranking?
I assume youve checked the obvious like cambelt?
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 18-09-2018   #3
Hi Robert
Didn't even think to check the cambelt 😮
What would I be checking it for?
I'll look at that before I try anything else but I guess if it is the cambelt it might be too late already???
Old 18-09-2018   #4
Timing belt snapped.
Old 18-09-2018   #5
s130 has donated!
Would also add that you have several related and unrelated fualt codes.
All modern cars, Croma included, are very sensitive to good quality electrical supply. Anything less than ideal can and will result in all sorts of error codes.
Suggest you check battery state, battery connections and chassis earth strap.
Regarding battery Halfords (and possibly others) will check battery condition for free and you are not obliged to buy a battery from them if it yours fails. My Halfords and I presume all national braaches use the same/similar testing kit. They enter your battery make, model, etc. on their kit, run the tests and give you the results in a printout.
Rest is up to you.
s130 is offline Reply With Quote Quote
Old 18-09-2018   #6
Quote Originally Posted by s130 View Post
Rest is up to you.
Thanks S130, timing belt snapped.
Old 18-09-2018   #7
Anybody have any suggestions to check whether my 8v 120 is wrecked?
Old 18-09-2018   #8
Looks like the water pump might have siezed. Not that old either, full skc timing belt kit from ecp a few years ago.
Old 18-09-2018   #9
Moderator
g8rpi's Avatar
g8rpi has donated!
Sorry to hear the belt has snapped. Virtually all diesels are "interference" engines so valves can touch the pistions. The mJTD is supposed to have weak points in the rocker arms to prevent major damage. But it will need investigation.
Robert G8RPI.
Old 18-09-2018   #10
Moderator
g8rpi's Avatar
g8rpi has donated!
Charlie Trent (used to be my local breaker years ago) have a complete engine for about 500.
https://www.ebay.co.uk/itm/2005-FIAT-CROMA-939A1-000-1910cc-Diesel-Manual-Engine-with-Pump-Injectors-Turbo/273203128137
Recon head 180
https://www.ebay.co.uk/itm/FIAT-SAAB...D/202405820225
Robert G8RPI.
Old 18-09-2018   #11
Cheers Robert appreciate it.
I'm guessing that means opening it up?
I've looked at a couple of posts on other websites and which suggest changing the pump and belt and giving it a try just in case. It was doing about 25 at the time. Sensible suggestion in your opinion?
Old 18-09-2018   #12
Moderator
g8rpi's Avatar
g8rpi has donated!
Sensible if you can do it yourself. Ideally check the valve clearances first. If the rockers or valves a bent the clearance will be large.
eLearn implies its easy to get the tappet cover off.
1/ Plastic cover off.
2/ remove 2 vapour pipes
3/ remove bolts
But there is no drawing.
Camshaft cover looks like a bit more work.
Robert G8RPI.
Likes The Panda Nut liked this post
Old 18-09-2018   #13
Robert you are a star.
I'm trying to find a YouTube video but I'm obviously not typing in the right combination of buzzwords and can't find one.
Old 19-09-2018   #14
Hi Robert, once I've got the rocker cover off, if the rockers are damaged how obvious should the damage be?
Old 19-09-2018   #15
Very obvious! Rockers snapped in half. As before,check valve clearances.massive gap means bent valves.
multipete is offline Reply With Quote Quote
Thread Tools
(G) Fault codes, if you know the meaning of any codes please post them here bigdong Scudo 36 13-09-2016 12:22
(T) broken down P0170 & P1325 fault codes ballboy Punto (Mk2/2b) 99 06-04-2015 12:05
Fault Codes Gertie Gooner Newbie Central 0 07-04-2013 11:57
(T) Help on fault codes stevepearce Punto (Mk2/2b) 17 01-08-2012 10:41
(T) Fault codes newtofiat1 Stilo 1 25-04-2012 00:42
