General Blower motor won't shut off
juredi
Croma 2006. The blower motor won't shut off, no matter how you set the control, it runs even the car is OFF. I disconnected the battery cable to stop the blower:bang:
Do you have simple air conditioning or the dual zone climate control?
If it's just air con it is probably a stuck relay. If climate control it could be a faulty electronic speed control unit. In either case it is also possible that a damaged wire could cause issues. Has anything else been done to the car recently? You can pull a fuse to stop the fan rather than disconnecting the battery.
Robert G8RPI.
It is dual zone climate control, and the failure appeared suddenly, no actions to the car. Please could you show me the specific fuse of the fan, and where can I find it ? Thanks
Hi according page 176 to the handbook ( download it here https://www.fiatforum.com/downloads.php?do=download&downloadid=105
) The climate fan is on fuse F2 (40A) in the engine compartment fuse box.
Image is on page 171 and it's the second fuse up from the bottom on the line of large fuses.
SKouHtqsDMQAAAABJRU5ErkJggg==
KYOnMFXg1TJ4CoVCoVAoFCaGmvcuFAqFQqGw61EGT6FQKBQKhV2PMngKhUKhUCjsepTBUygUCoVCYdejDJ5CoVAoFAq7HmXwFAqFQqFQ2PUog6dQKBQKhcKuRxk8hUKhUCgUdj3K4CkUCoVCobDrUQZPoVAoFAqFXY8yeAqFQqFQKOx6lMFTKBQKhUJh16MMnkKhUCgUCrseZfAUCoVCoVDY9SiDp1AoFAqFwq5HGTyFQqFQKBR2PcrgKRQKhUKhsOtRBk+hUCgUCoVdjzJ4CoVCoVAo7HqUwVMoFAqFQmGXYzb7vyEFvmiIUYPYAAAAAElFTkSuQmCC
LqbYXikr+bQAAAABJRU5ErkJggg==
Hope this helps.
Robert G8RPI.
