Technical Steering getting heavy
Rajoana
Got a 2008 croma(194) 2.2 with an electronic steering.
Over the last year its been getting heavier. Need some real effort to turn at slow speeds.
How cld i resolve this?
I'm assuming that since 2005 the 2008 Croma still uses the Electro Hydraulic steering.
If you are detecting a long term progressive decline in steering assistance then it is probably not electrical related (bad, lose, corroded power cable connections etc) but probably a decline in the efficiency of the electric hydraulic fluid pump.
You should however get the electrical connections/cable checked as this is a common issue with older/aging Croma's.
Also worth checking the Vauxhal/GM forums. https://www.vectra-c.com/
Alrite. thanks for the reply. Hope can get this sorted out soon.
