Hi all our jtd150 is showing signs of cylinder head gasket trouble it has never needed its coolant topping up! But it has now started to overflow at the expansion tank not much but a commute to work is enough to put a bead of pink coolant around the seam around the tank. I have ordered a new cap for the expansion tank, a new thermostat and I will change the coolant (it has been in over four years) if that does not work I will try K-seal though I am not keen on additives’ a look on Ebay at z19dth cylinder heads reveals that they do corrode so it will need skimming, a new gasket and bolt set. Still can't complain it has been trouble free for ages.
