Off Topic fiatecuscan
Africano
Hi everybody
I have a fiat croma 1.9 multijet 16v , I need fiatecuscan to reset service and checks for erros, Ive read that the only version that free and works is fiatecuscan V1.6.
Ive looked online and can,t find it. I'd be grateful if anyone could help
thankyou.
Hi everybody
thankyou.
It's been renamed Multiecuscan (maybe Fiat complained) download from www.multiecuscan.net You can try the free version and then register. It's only €50, cheaper than a single diagnostic by many garages. Any working "copy" is a crack. If people use cracked software the original authors will give up and we all loose. You also need an interface, a good choice for a Croma is an ELM 327, e.g. ebay item 301626849586.
With the 1.9 16V you need to reset the oil degredation counter as well as the service light. If you don't do this the DPF can fail due to non-regenertion.
HTH,
Robert G8RPI.
Thankyou
Ive download from this site but can,t do servicse reset. Only managed to clean errors
Gives me error, says failed to comunicate.
im using ELM 327 V1.5
You need the registered (paid for) version to do resets. Has your interface been modified? Many of them have a 120 Ohm resistor connected the CAN bus which should not be there. It causes some connection issues, if you have the registered version of MES you should check the interface. You need a multimeter to do this. Measure the resistance between pins 6 and 14 of the ELM327 interface. If it is about 120 Ohms (less than 200 Ohms) the interface needs modification by removing the resistor.
Robert G8RPI.
