Hey guys!
A few months ago, I've noticed that my rear right door isn't locking. When I lock the car, all of the doors lock except the rear right door. The sound of the locking mechanism is heard and I can confirm, that the central lock motor is not the issue.
The door lock has a hole in which you can put the key, which you extract from the cars lock remote. You can flip this switch with the key, one position meaning that the door can be opened from the outside door handle and the other position meaning that the door can't be open from the outside. Well this switch is somehow stuck and cant be fliped. If I activate the deadlock mechanism (pushing the lock button on the remote twice), this sometimes helps the door lock to get unstuck, but then again after a short while it gets stuck again. When it gets unstuck I can flip the switch with the key, but the feeling of changing positions is not the same as on the other doors. Did anyone of you face a similar issue? Is fhere a online store maybe, that has this rear right door lock mechanism on stock? I've been searching for it online for the past two hours but didn't find anything useful.
