Thread Tools
Old 13-10-2018   #16
varesecrazy has donated!
Quote Originally Posted by Mattsmith1972 View Post
I know this is an old post but I've had a similar problem, my local garage has cleared the oil service indicator with a snap on obd reader but it keeps triggering the EMS light so I can't get anywhere near the motorway to regenerate... I'm in Nottingham...
Hi.
Did they do the oil change?
As THEY should have reset the parameters also..
Common issue with small garages..
They charge to do a job.. but cannot do it properly due to lack of kit or knowledge ..means the owner has to do all the remedial work.
Charlie
Old 19-10-2018   #17
Re: P2002 Code and DPF won't Regen
Connect to the ECU using mes and see what the oil degeredation is at. If the it's been reset properly the oil will show 95% or thereabouts which is good. It will also show something like 20,000kms to next change.
Full mes can force a regen but the exhaust gets very hot so be careful where you do it.
BrianMcL is offline Reply With Quote Quote
Thread Tools
(T) DPF clogged, regen failed maybe? dave Croma 100 14-11-2014 11:42
(T) Regen. Brittleware Ulysse 4 23-09-2013 18:52
(T) Regen issue bravosl165 Bravo 9 05-09-2013 23:53
(T) DPF regen Problems stuart543 Croma 30 29-10-2012 15:31
(T) Help with regen for doblo dpf Petesee101 Doblo 9 09-07-2011 23:10
