Old 14-07-2015   #1
Albania
Question Cannot lock the back doors with the key.
Hello,
I cannot lock and unlock the back doors. they work normally but they just can't be locked. Also the tailgate acts strange. normally it cannot be opened by the electric button at the door, but it can be opened by the key anytime. When the car has moved for a while(ex.after a trip) the button can open the tailgate. I think it is an electric issue but I'm not that sure. your help will be appreciated.
arbervehbi is offline Reply With Quote Quote
Old 14-07-2015   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Cannot lock the back doors with the key.
Does sould like a loose connection. Most likely areas are the body computer / Junction box behind the little cubby box (by the drivers knee on right hand drive) in the dash. Second is the junction box in the luggage compartment. You can download the eLearn eletronic manual system from the forum. This has location diagrams.
Loosen each plugs, relays and fuses and push them back in (one at a time).
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 15-07-2015   #3
I had always had a similar problem with the tailgate only sometimes opening with the remote. The same with the button on the latch. I normally found that by locking the car and then unlocking it, the remote would work on the tailgate again.
Someone around the forums said that this may have been an earlier software problem that was fixed in later upgrades.
It didn't seem worth the expense to have the software upgraded so I lived with this anomaly for quite a while.
Recently (see other threads) I have had Ignition, Steering Lock and Body computer replaced. Apart from my car now working just like it did before all the problems, my tailgate locks and unlocks, opens and closes as expected using either fob or fingers.
Only cost about a grand to get that one enhancement!
Regards
Gaz
gazskeltz is offline Reply With Quote Quote
(T) Key fob will not lock/unlock doors. brownbob Doblo 7 28-07-2015 21:26
(G) lock doors on ducato millenniumpool Ducato 6 13-06-2013 11:27
(T) I cant lock my doors ger Cinquecento / Seicento 3 24-10-2004 19:49
Doors lock and unlock themselves Paul Maks FIAT Boo Archives 3 10-04-2004 16:24
Lock on the Boot is jammed!!! i have tryed to get in with the key but the key wont turn... Paul R FIAT Boo Archives 8 22-01-2004 21:28
