Technical Fitting Parrot handsfree in Croma
bvader
Hi guys,
I've searched the forum a bit but dind't find any solid answers or how to's on how to properly install the Parrot handsfree into Croma.
I have a Parrot CK3100 that I previously used in my Honda Civic and now, I want to fit it in my Croma. I have the Connect Nav+ unit in the car. When I was installing the Yatour digital media changer I noticed that the connectors that go to the navigation unit are standard ISO connectors, am I right?
After googling a bit I noticed that most Fiat cars don't have the ignition +12V and constant +12V on these ISO connectors and you have to get the power from somewhere else? :eek: From where is it safe to take the power for Parrot? I hope there is someone here, that has went through this process in his Croma and can give me some advice :D
I have connect+, all I did was insert the Sim card in the slot and use the existing system.
In 7 years I have received 3 calls and sent 1.
Keith
I've allready tried the above mentiond solution but one of the problems is that I have to get another SIM card for the connect nav+ which will cost me 6€ per month which is alot considering that I allready hava a parrot device ready to be installed :). The second problem is that the contacts aren't synchronized with the phone, I receive a fair amount of calls while driving so for me, handsfree device is a must.
