Thread Tools
Old 1 Week Ago   #31
Quote Originally Posted by BrianMcL View Post
Starting point with anything egr or dpf related is to make sure that the oil change indicator has been reset. MultiEcuScan (mes) on a laptop will let you check.
If it was happening all the time the next step is to disconnect the maf but in your case I'd probably jump to step 3 which is block the egr and see if that fixes it. The check engine light will come on but don't worry about that at this stage.
Once we've eliminated the cause of the problem and removed the blocking panel you can either reset the check engine light with mes, a handheld fault code reader or switching the engine on and off a few times and it should clear itself.
BrianMcL is offline Reply With Quote Quote
Thread Tools
(T) EGR valve problem mark.white19 Stilo 15 01-04-2014 15:59
(T) EGR valve problem on Bravo 1.9 120 M-Jet totalester Bravo 10 27-11-2013 10:39
(T) Could this be the EGR Valve Problem.? BaRoN30s Stilo 20 08-09-2012 10:14
(T) Egr valve problem...again?? Bravo Chris Bravo 12 05-03-2012 17:41
(T) EGR valve problem? philipb82 Stilo 19 20-02-2012 10:00
