Yes key programming, other than remotes, is a lacking function which often comes up for discussion.
This is also a prime difference between
MES & AlfaOBD.
I've only ever used
MES (not AlafaOBD) (from its first original FiatECUScan origins) and the key programming has always been a current topic.
Yani (
MES originator/coder/owner) has deliberately thus far excluded key/security reprogramming functions from FES/
MES because a simple user error, or indeed a user hardware error, or even a FES/
MES programming error COULD RESULT IN A DEAD CAR.
Remember if you go to a Fiat/other dealer and they kill your car that is their responsibility and they have to repair the damage/operability of your car.
If
MES were, for what ever reason (like you screwed up), to kill your car then you wuld be really *issed off and looking for damages/reparation etc. etc. within a rapid period.
For now,
MES will I believe avoid these complications/liability under its current licensing program.
As key programming is still actively pursued by
MES users (including PRO shops) then this ability is not off the
MES radar so may be coming in the future.
Remember a single/simple/other error with key programming can leave you with a dead car!!!!!!!!!
