Hello,
I would like to share with you once again (I mentioned it some months ago in another thread) an issue with a squealing alternator belt. Please, look at that video of a cold start:
You'll see that the belt starts squealing in case of a big current consumption and this squealing stops as soon as the voltage goes above 13.2 V. It looks like the alternator is working lazy. I'm wondering, is it an electrical (inside the alternator - diode rectifier, voltage regulator, stator coils ...) or a mechanical (belt, alternator pulley ...) issue.
I have had this problem since I've bought the car 1 year ago. The alternator is working fine, according to my understanding. It charges the battery at 13.7-13.8 V. The issue is not critical, but is very annoying. That is why I'd be happy, if I can resolve it in a cost efficient way. Please, note that all belts and belt tensioners were replaced 1 year ago. The elastic alternator belt has been replaced even twice, because of a clue, that it should be original (first one was Contitech). The battery is also new (85 Ah Varta).
Is there anyone that experienced the same or similar problem? If yes, what was the resolution?
Thanks and best regards from Bulgaria!
