gazbat106
When popping out to the shop a number of messages scrolled in the display, starting with EBD failure, then ABS failure, then Power steering failure, then insufficient oil pressure. all accompanied with beeps. I had the headlights on at the time and all lights went off except the radio illumination (even the backlight for the display went off). Managed to wrestle the car home with no power steering.
something similar happened last year when the alternator went, but when this happened the battery light came on 1st. No battery light this time.
Any Ideas of what this may be? Could it be the battery or bad earth?
Also, not sure if related, my drive to work is approx 20 minutes, on the odd occasion the passenger side rear brake starts to squeal approx 10 - 15 mins into the journey. Dabbing the brakes sometimes stops it. Never happens on short journeys. Could they just need stripped down and cleaned?
