Technical Replace Mp3 radio with NAV
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Dule
Rijeka
Hi to everybody,
is it possible to swap original Croma mp3 radio with original Croma NAV radio. Are the connectors the same and which functions will work if somebody know?
They are swapable but they are expensive to buy even second hand (if you can find one). Not sure about the wiring but I have the Prestigio model and can fit one if I wanted. But wether the wiring is the same on eleganza / dynamis I am not sure.
I enquired about this when I first got the car( 2009) and was quoted £300 fitted but when the dealer checked he said there were non in the country and it would have to be ordered from Fiat Italy. I had already bowled the idea out due to price and an order from Turin put the tin hat on it.
There is a thread on this somewhere, use Thread tools to find it.
It is not a straight swap.
I have (somewhere) the wiring diagram to do this which I purchased from ebay (italy). No idea where I've put it though :D
Having previously retrofitted the full sat nav/DSP/Telephone/Changer monte in a 166 which included making a lot of the loom from scratch, then I have to say that the instructions were not that daunting to be honest - although a virtual strip out of the seats, lower console, some headlining (not as bad if you have the sky dome) would put a lot of people off.
tarqs is correct re price - the cheapest currently in the cars homeland on ebay is £250.
The other thing you need to do (which was not a requirement on the 166) would be to wire in a time-delay for it to power-up to avoid upsetting the canbus body ecu.
Definitely do-able if you can find the kit (WITH THE CODE!!!!) for the right price and have the time & patience (the 166 took the best part of 2 weekends to do it properly).
If I do ever track down a reasonably priced unit then I personally will go for it probably for the hell of doing it........ but if before then Mirrorlink ever gets there ar$e in gear and finally starts to cover windows phones as they have been promising for the last 18 months then I'll be going down that route instead.
