Can someone tell me what the upper end of the tube is connected to. There's no pipe in mine at all and I'm plagued by misting with heater on but aircon off.
Well this is a conundrum and no mistake. One thing is really puzzling me was when you said the window screen man cleaned out the drain on the drivers side?? Is your car LH drive????2005 blue badge. Water drains where wipers are. I can categorically state no drain hole in plastic below windscreen. Just had windscreen replaced, I was shocked that it was in stock, windscreen guy cleared scuttle hole on drivers side but I still get misted windows when heater is blowing to screen, only clears with aircon on. Maybe problem with heater matrix in which case I'll stick with aircon on to clear screen.
