Having another problem on the croma ,the steering wheel is juddering and making knocking noises when stationary so I am guessing pas pump.
I have had a look at the power connector and it looks ok.on faitscan it reads
Volt 13.7 Constent
Rpm is up and down like a yoyo
Amps is up and down like a yoyo 10 to 56 amp
Got hold of a vectra one to have a look what's inside .looks like the mechanical part off the pump might be the same the problem is the electronic control board
The problem is I need the car on the road for work so vary limited on time .
If it a mechanical problem should be able to fix it .
Electronic it's touch and go .
What is the fastest ,easiest way to get the pump out of the car
Thanks Gaz
Volt 13.7 Constent
Thanks Gaz
