I am posting this for Doofer and who else might have similar problems. As far as I know this issue is usually cause by the brake fluid not being able to get back through the brakes split circuit valve, I am not sure where that it is part of the servo unit. What I think happens is that if you apply the brakes hard these 2 brakes stick, especially the front o/s. Obviouly the brakes are split for safety, so that these 2 are on 1 circuit, its always seems to be the front o/s and rear n/s that drag. I believe there may be other posts on here about this.
