Old 23-01-2015   #61
Vento has donated!
Netherlands
Re: Broken thermostat - Is it difficult to change?
[QUOTE=Telegraph;4018437] new clip refill and hopefully job done
Thank you very much for your quick reply, before job done I need to refill and evacuate the system, is it straight forward, filling, running the engine and top up or do I need to open sudden bleed nippels to get rid of air pockets?
Vento is offline Reply With Quote Quote
Old 23-01-2015   #62
Hi Vento I did not bleed the system as such just refilled and squeezed the large hose a few times and did not loose much coolant any way but do double check after start up.
Telegraph is offline Reply With Quote Quote
Old 23-01-2015   #63
Vento has donated!
Netherlands
Dear Telegraph, thank you for helping me out.
Vento
Old 17-02-2015   #64
Vento has donated!
Netherlands
Quote Originally Posted by Telegraph View Post
Hi Vento yes pretty sure that is what I used it fits old Volvo 360 and some other cars. It fits into the large rubber hose from the thermostat housing to the radiator to the left of the battery. It involves removing the hose clamp and pulling the hose off then the only tricky part pushing the stat into the hose the YouTube bloke used grease to help I used neat antifreeze as a lubricant and it is a tight fit a tube or large deep socket helps to push it that last 25mm be careful not to damage the bulb thing. As you refit the hose you will see that the bulb fits nicely into the housing, new clip refill and hopefully job done. Ours is still fine last summer on our holidays it had a stiff test and no trace of overheat. The temp needle should rise to halfway fairly quickly even when it's freezing. I do not understand why FIAT fitted this over complex difficult to access expensive and unreliable thermostat assembly so many thanks to youtube gentleman!.
http://www.ebay.co.uk/itm/VOLVO-340-360-1-7-1-4-83-91-Replacement-Thermostat-/301102201921?pt=UK_CarsParts_Vehicles_CarParts_SM& fits=Car+Make%3AVolvo&hash=item461b16fc41
Fitted this old Volvo 360 and Renault thermostat: first removed the engine under tray and placed a bucket to catch the cooling liquid from the disconnected hose. About 3 litre liquid poured out after loosening the hose. Was able to press the thermostat 25 mm in the hose as visible on the video (not an easy job). Connected the hose again with adjustable jubilee clips instead of the originals. Filled the system with the catched old liquid and drove around till the engine was on temperature. Topped up with half a litre new liquid. Drove about 1500 KM since and experienced the result as very satisfying. Will keep an eye on it.
Old 17-02-2015   #65
Hi Vento that's great it took me some time to get the stat in to the hose but still much quicker than changing the original!
(T) How difficult is to change a starter motor on a MK1 Punto black bravo man Punto (Mk1) 5 26-07-2012 20:18
(T) Difficult gear change Durks Bravo 3 27-05-2011 19:22
(T) Cambelt change: how difficult is it? tomfoster Stilo 5 29-11-2010 19:46
(G) Notchy, difficult gear change nallen132 Croma 8 07-05-2009 21:09
(T) how difficult is a cambelt change on 1.9 jtd? pupplington Doblo 0 20-01-2009 19:12
