Old 20-09-2012   #1
Romania
Question Engine Oil Dilemma - What type of oil do you use ?
I bought my 1.9 16v used with 152.000km from a local dealer which I asked then if the car is fitted with DPF and they said no. After 5000 km I went with the car for a regular diagnosis, just to check if there is a problem and I find out that the car is fitted with DPF . In the manual the recommended oil is Selenia WR 5w40 that pass FIAT 9.55535-M2 specifications. Now the Selenia WR 5W40 I used is FIAT 9.55535-N2 and I guess/hope N2 is better/newer than M2. The dilemma is this ...I saw Selenia WR 5W30 with FIAT 9.55535-S1 and I do not know if this is better than the one I already have in the engine. In FiatEecuSscan the DPF average distance last 5 regenerations is 1205km.
FIAT 9.55535-M2 Qualification for lubricants with extended drain
FIAT 9.55535-N2 Qualification for lubricants with a very good characteristics for turbocharged engines, Diesel and gasoline, with extended drain.
FIAT 9.55535-S1 Qualification for Diesel and gasoline engine, with exhaust treatment system, lubricants, granting fuel economy and extended drain.
On my previous owned cars I used only Liqui Moly engine oils and two weeks ago I sent a e-mail to Liqui Moly regarding the type of oil I should use from them in my 1.9 16v. That happened before I found out that my car is fitted with DPF. I`m posting the answer if anyone is interested:
"Many thanks for your inquiry dated 05.09.2012 and the interest in our
products.
We have checked your inquiry and we can recommend the following products
with particular filter Top Tec 4100 5 W-40 Art.-Nr. 3701- 5 liter
without particular filter Leichtlauf High Tech 5 W-40 Art.-Nr.3864 - 5 liter
We can also recommend you an oil additiv with MoS² our
Oil Additiv Art.-Nr. 1011 - 125ml"
I want to use the oil which is best to ensure a long and happy life for my engine.
Did anyone tried the Selenia WR Pure Energy 5W30 ?
What type of engine oil do you use ?
Fiat Croma Emotion 1.9 Multijet 16v 150hp
Roberto Blanco is offline Reply With Quote Quote
Old 20-09-2012   #2
s130 has donated!
Re: Engine Oil Dilemma - What type of oil do you use ?
I currently use
Castrol Edge Turbo Diesel 5W-40 Engine Oil (Croma)
Fully synthetic oil
Fuel Diesel
SAE 5W-40
VW 502.00/505.00/505.01
MB 229.31/229.51
BMW Longlife 04
Renault 0700/0710
Meets Ford WSS-M2C917-A
ACEA A3/B3/B4/C3
API SM/CF
The above spec. was in 2011. I believe they changed / increased the specs since then.
I have a spreasheet with a number of oils I gathered specs on. I chose Castrol Trubo Edge diesel becuase it met the required specs, is a good quality make and readily available.
These are quite I few suitable oils out there.
s130 is offline Reply With Quote Quote
Old 20-09-2012   #3
You're actually worried about what brand to put in?!
I'm currently using Asda oil, was previously using Wilkinson (I'm not joking). All of the correct grade as specified in the manual, meets all sorts of requirements.
The car's been running beautifully with it for 3 years/40k miles, couldn't be better. You could probably buy genuine snake oil for the same price as the Liqui Moly Hyper Sooper Dooper Plus.
Yes, I'm a cynic.
Likes gazskeltz liked this post
Doofer is offline Reply With Quote Quote
Old 20-09-2012   #4
Trader Rating: 10
dave has donated!
i use Selenia WR Pure Energy i think,
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 21-09-2012   #5
The engine oil has to be low ash oil and this is indicated by a C in the spec.
C1 C2 etc
Thanks Doofer thanked for this post
Likes Roberto Blanco liked this post
Granvilleb is offline Reply With Quote Quote
Old 21-09-2012   #6
s130 has donated!
What confuses me is that when you look at a top quality (say Mobil or Castrol) oil then it can get very confusing because there is often a huge overlap in specifications between Petrol & Diesel Oils of the same brand. This makes it difficult for all of us but in my experience you must check the specs & details, match them to what your vehicle manufacturer specifies and buy what you are comfortable with and the "Diesel" or "Petrol" tag is a final decider. What I'm saying is the many petrol engine oils in 2012 meet or exceed the diesel oil specifications of say 2010.
Of course top notch, top spec, latest oils of 2012 are (or should be) better than oils of 2010 but there may be a high price premium to pay in running at the bleeding edge of oils when a little prudent research will deliver an oil that is more than adequate and meets all warranty etc. terms of the manufacturer.
Old 21-09-2012   #7
halilson has donated!
I was surprised to find that my (diesel) Marea 130 JTD used the same oil filter as my (petrol) 20V Turbo Coupe! Furthermore, from the block down, the two engines are practically identical.
halilson is offline Reply With Quote Quote
Old 21-09-2012   #8
Quote Originally Posted by Granvilleb View Post
C1 C2 etc
Thanks. The Wilkinson at least isn't rated as low ash, so I guess that's not recommended. It seems to work though - I'll have to follow Dave's lead and backwash it with the jetwash if it ever gets blocked.
I just find it hard to imagine that the (say) one litre of oil that gets burnt every year is in any way significant compared to the thousands of litres of diesel. Presumably diesel isn't zero ash, especially as the fuel companies add detergents and other additives.
Old 22-09-2012   #9
Romania
Quote Originally Posted by Doofer View Post
No, I`m worried about the grade. All I want to know if Selenia WR 5W30 is better than Selenia WR 5W40 to use in a JTD engine with DPF. The brand for me is either Selenia or Liqui Moly. Selenia because is the original oil recommended by Fiat and Liquy Moly because is very good and only manufactured in Germany, not like other brands which have factories all over the world and can be easy counterfeit. I don't know what is the situation in your countries, but in Romania you'll never find genuine Mobil, Castrol or other top brands. It's a big market, the profit is huge, and that's why it gets counterfeit. Same it's with the olive oil in Italy for example, the business is bigger and more profit is made from this than with the drugs, because it is easier to move tons of olive oil. In conclusion, I want and I use only trusted brands from which I can be 100% sure that the product is genuine.
Here 5 liters of Liqui Moly is more cheaper than Selenia WR with almost 50%.
Old 23-09-2012   #10
arti_abarth has donated!
i use selenia WR 5W40 FIAT 9.55535-N2, I'm very happy with it, as is my car
i'm changing it every 10-12k miles, did 5 changes now since i got my car
arti_abarth is offline Reply With Quote Quote
Old 26-09-2012   #11
the notorious one
notorious's Avatar
notorious has donated!
Serbia
Selenia WR Pure Energy is the correct oil for a dpf equipped cromas.
Serbia is not suburbia.
notorious is offline Reply With Quote Quote
Old 26-09-2012   #12
Moderator
Peter Pick-Up has donated!
Russia
Quote Originally Posted by s130 View Post
I currently use
Fully synthetic oil
Fuel Diesel
SAE 5W-40
MB 229.31/229.51
BMW Longlife 04
Renault 0700/0710
ACEA A3/B3/B4/C3
API SM/CF
I use the same Castrol in my 2004 Alfa GT jtd with 150hp 1,9-16V Fiat Diesel engine!!
Peter Pick-Up is offline Reply With Quote Quote
Old 27-09-2012   #13
Romania
I'll stick to Selenia WR 5W40 for now. I saw that in the user manual of the mkII is specified also Selenia WR Pure Energy 5W30, but taking in consideration that during the summer we have here 40 degrees and in the winter -25, 5W40 remains a better choice.
Old 27-09-2012   #14
I use 5w40 Valvoline, with the correct low ash rating, but will be able to save a few pennies at my next service because I no longer have a DPF to worry about! Win win all the way
Old 01-10-2012   #15
VW/Audi Platinum, 5w40 fully synthetic designed to cope with massive cam loading in PD engines - this oil will deal with just about anything! It's not DPF suitable but like Halison my DPF is soon going to be long gone. Change every 10k/1 year.
Greg123 is offline Reply With Quote Quote
(T) Twinair engine oil ...when is an oil not the correct oil ? iangray100 500 16 06-03-2012 16:03
(G) oil pump dilemma greenbomber69 Panda (Classic) 14 22-08-2008 18:03
(G) Type of engine oil ? Peter 171 Punto (Mk2/2b) 2 01-08-2006 21:07
(G) engine oil dilemma/whinge! MintySport Cinquecento / Seicento 2 24-08-2005 11:30
