I bought my 1.9 16v used with 152.000km from a local dealer which I asked then if the car is fitted with DPF and they said no. After 5000 km I went with the car for a regular diagnosis, just to check if there is a problem and I find out that the car is fitted with DPF . In the manual the recommended oil is Selenia WR 5w40 that pass FIAT 9.55535-M2 specifications. Now the Selenia WR 5W40 I used is FIAT 9.55535-N2 and I guess/hope N2 is better/newer than M2. The dilemma is this ...I saw Selenia WR 5W30 with FIAT 9.55535-S1 and I do not know if this is better than the one I already have in the engine. In FiatEecuSscan the DPF average distance last 5 regenerations is 1205km.
FIAT 9.55535-M2 Qualification for lubricants with extended drain
FIAT 9.55535-N2 Qualification for lubricants with a very good characteristics for turbocharged engines, Diesel and gasoline, with extended drain.
FIAT 9.55535-S1 Qualification for Diesel and gasoline engine, with exhaust treatment system, lubricants, granting fuel economy and extended drain.
On my previous owned cars I used only Liqui Moly engine oils and two weeks ago I sent a e-mail to Liqui Moly regarding the type of oil I should use from them in my 1.9 16v. That happened before I found out that my car is fitted with DPF. I`m posting the answer if anyone is interested:
"Many thanks for your inquiry dated 05.09.2012 and the interest in our
products.
We have checked your inquiry and we can recommend the following products
with particular filter Top Tec 4100 5 W-40 Art.-Nr. 3701- 5 liter
without particular filter Leichtlauf High Tech 5 W-40 Art.-Nr.3864 - 5 liter
We can also recommend you an oil additiv with MoS² our
Oil Additiv Art.-Nr. 1011 - 125ml"
I want to use the oil which is best to ensure a long and happy life for my engine.
Did anyone tried the Selenia WR Pure Energy 5W30 ?
What type of engine oil do you use ?
products.
