Old 01-03-2012   #16
s130 has donated!
Re: A busy day!
On the back side of theplenum chamber about halfway along, beteen the back of the EGR valve and the back of the fuel pressure/return regulator. Single bolt fixing (kex socket head). Has small internal 'O' ring. Connector points upward and has RHS cable entry. Lift the little yellow tab up to unlock the connector before attempting to pull it off.
Best done with engine warm as the closeby rubber pipes then easily defeflect to allow hex key access.
I've cleaned mine with neat diesel fuel and also brake cleaning. No issues at all. Put a thin smear of moly grease around 'O'ring before replacing.
WARNING! DO NOT poke inside the plastic cage head as there is a floating wired component just inside (probably a temperature measuring device).
s130 is offline Reply With Quote Quote
(G) Busy day with the sisley..... usedtohaveavaldisere Panda (Classic) 4 06-03-2010 17:09
(G) busy day...... Jai Uno 10 03-06-2009 19:29
Cinquecento Busy day with the Cinqi Bushboy Members Motors 7 09-02-2006 16:16
A busy day under the car Gary Bodyshop 4 26-09-2005 12:24
