Hi
I have had an issue with my 1.9 150bhp Diesel croma.
I have purchased to FiatECUScan programme and it reads to ECU fine, and clears my fault code, DPF issue.
However, all the parameters work except for the Lambda sensor figures.?Would this mean the Lambda sensor is not working.
The car had a split turbo inlet hose, and then threw the engine light. I replaced the hose but have had the light flash up (and go into limp mode) every 3 miles or so since.
I have cleared the code every time with the FiatECUScan programme, but I cleaned the two Lambda sensors (one in mandown pipe and one in DPF), and now it run for about 10 miles before the light came on. I then cleared the code and did a DPF regen (thats interesting!!!!).
I have recently changed the MAP sensor also.
Just wanted to know if other members here have values for the lambda when stationary?
Dave
Dave
