General Croma Wiper Linkage Rods
Thanks tarquin, I presume this is between the windscreen and the trim. Should the trim then push back in?
Thanks again
Yes there are two sections you may have to remove both to get at the linkages as one overlaps the other.
While you are under there I would recommend changing the pollen filter and cleaning the drain tube from the top of the trim and cleaning out the flap valve in the bottom of the scuttle that allows the water to escape under the car .
A thread about this I started is on the forum, use "thread tools" at the top of the page to access it, there are photos` and lots of advice. Hope yours is not as mucky as mine!! ( Had to park under a sycamore tree, now thankfully gone:)
Its how to remove the plastic trim from along the length of the Window screen that i need to clarify.
It just sits against the windscreen and if my memory serves me it has a few location points which marry up to the steelwork at the back of the engine compartment .
OK thanks, i will have a better look over the weekend. And give it a pull and a push :)
Im glad my measurements worked then!
I just reviewed the dates of my previous posts, and the replacement rods lasted about 7 months. I then replaced them with new ones, plus the clips and so far they've been fine for 18 months (and still working and judder-free).
The problem is the combination of the socket facing upwards, plus the fact that the Wipex rods are heavier than the originals. Really Wipex should be bundling clips with them where the sockets face upwards. Gravity will beat friction in the end, and all your lovely grease will probably help it to fall off.
I have remembered about the rust issue on the clips though, from reading it. I will now hunt for some rustproof ones.
Edit: I've ordered four (2 pairs) of these for a tenner. Different design, diferent seller, zinc plated (yay!)...
http://www.ebay.co.uk/itm/221282460295
I'll update this thread after I try fitting them.
Once again I bow to your abundant knowledge (and common sense) My Wipex linkage dropped off after 12 months. I have now ordered new stuff from Wipex plus the galvanised clips.
Nothing like belt and braces for the next lucky? owner.
I'll miss the old girl
Thanks for your (over) kind words!
I never got round to trying the plated ones, so I can't say for sure that they'd fit. The rusty ones did keep working until it was sold a few months ago, and I sold the clips on ebay a couple of weeks ago.
Good luck with it. I don't miss my Croma one bit. If anyone is looking for a very capable replacement then don't dismiss the Berlingo Multispace without a test drive - I'm still shocked at just how good it is. Zero posing points, but it's a huge load-lugger for the price of a Fiesta.
I ordered the clips, but cant seem to get them on with the replacement Wipex linkage..The clips look too close to be able to slide over the link arm.. If anyone has used the clips with the replacement arms, Can they please let me know where to get them from THANKS :)
I did put some words and pictures about it somewhere. I cut a little notch into the rods with a hacksaw, in the right place for the clip's tab to clip into.
If you start from the beginning of this thread there are some photos somewhere showing the clips fitted. After this I cut the slots into the rods so they go on the other way, and the tabs slot into the rods.
Doofer thanks for getting back, however they don't seem to do those types of clips anymore :-( I have emailed the company, so hopefully they will get back to me with an answer.
Received an email from Ask the mechanic, off ebay, with regards to the linkage clip. They suggested item number 251752861634 on ebay. Not sure though as the Wipex replacement arms have wider ends.
Pleased I got a response .
New message from: askthemechanic Top Rated Seller (10975YellowShooting Star)
Our Fiat Clip fits the standard Croma linkage and the Wipex Punto linkage but I am not 100% sure about the Wipex Croma Linkage, but I would think it would.
Please search ASK THE MECHANIC FIAT WINDSCREEN WIPER LINKAGE MOTOR REPAIR CLIP or eBay item number: 251752861634
The "Ask the mechanic" ones are what I fitted, with the Wipex rods.
You can either fit them at 90 degrees to the rod, in which case you're relying on friction to keep them there (but they'll probably be fine), or you can do what I did and cut a small notch in the rod to make it much, much more secure...
Just push a clip over the end of each rod before fitting, draw a line where the tab rests against the bar, then remove it and cut into the bar by about 3-4mm. It will then be completely locked into place.
These lasted until I sold my Croma. But they did go rusty very quickly, which is why I would find a zinc-plated or stainless steel alternative.
Cheers guys, I just dont want to loose the use of my windscreen wipers at 70 mph ever again..
If you cut the notch into the rods as shown in my scribble diagram then it is physically impossible for them to ever come off, as you need to pull the clip out of the notch, against its spring, before it can be removed.
Without this you can put the clips on at a right angle to the rod, but you're then relying on friction - probably not a good idea, as it obviously twists in use.
Just put the clips on each rod end, make a pencil mark where they rest against the rods, then cut a notch with a hacksaw.
...and put white grease or silicone grease on every moving part before assembly.
Not standard grease, WD40 or oil as that would soften and degrade the plastic sockets.
Doofer, how do you remove the black trim that runs the width of the windscreen so that you can get access to the wiper motor and arms. Mine doesn't seem to want to come off.
Remove all clips, remove pollen filter lid then wiggle and pull up - try turning the clips a quarter turn then pulling out. If this doesn't work then pull the centre part out to unclip them.
Pull the trim off starting at one end and working across. It takes a bit of effort, as there's a lip that clips in along its full width. The rubber bits at the ends clip into slots in the pillars - I think, from memory, that they slide down to unclip.
Make sure everything's nice and clean, and that you get the slot into the groove at one end when refitting, then work across its full width to ensure it locates properly. Mine wasn't fitted right, due to a replacement windscreen company. I never got it to full clip flush against the glass again after their efforts.
