DoIDon'tI
Member
- Feb 17, 2008
- 470
- 81
No clutch to burn out, but the gearbox is only rated to 324 lb ft and they're more expensive to replace than clutches...look up 'Aisin AM6' for the specs. Then there's the chocolate driveshafts and poor ride on the 18" wheels. The grass really is greener, honest.
If you're going to do it right, spend some more money and get a 159 sportwagen with the 2.4 and a manual box and remap that. Or better still, a chipped BMW E39 530D tourer. The Croma is a 1700KG Vectra with a high centre of gravity ('Pig on stilts' springs to mind) and fitting Eibachs will make the ride even worse. Complete the sentence - "You can't polish a ....".
As you may have guessed, disillusionment with the Croma has set in after the weekend. Cracking a rib while trying to refit the aux belt tensioner doesn't help my feelings towards the car
The reason you don't see many for sale is that there aren't many in the country - I reckon less than twenty / thirty? Perhaps someone in the know could answer that one.
